casa 185 gearbox options?
Postby swissdean » Sun May 14, 2017 11:17 pm
Hi, have a casa 185 on a lince 125 and it won't pull anywhere close to when i had it on my li150 box, despite mucking with crown and front sprocket combination (now at 46x16) so looking at changing to an affordable gearbox swap (ie not LI150)...anyone running one on a GP200 box (which seems the most affordable and also suggested by rimini)..trying to get to a cruising speed of 60mph with the end output (it pulled this easily on the LI150 box)
thanks
ps also will be my first gearbox swap, so beyond stickys book any tips welcomed
swissdean
Re: casa 185 gearbox options?
Postby daniel whiteley » Tue May 16, 2017 9:19 pm
I e got a vijay mk1 in mine on 18x47 it's good, also was going to run one on my special which is essentially ally the gp box after asked my a few opinions from others and as you said dean at Rimini recommended
daniel whiteley
Postby ToBoldlyGo » Tue May 16, 2017 9:48 pm
Yes, I'm running a Casa 185 kit on an Italian GP200 gearbox. It's a good combination and goes really well. Power is always there.
Postby HxPaul » Wed May 17, 2017 2:26 pm
I have a Casa 185 with a Vijai Super gearbox and with 18x47 sprockets and an Ancillotti exhaust system,its the same as an Indian GP200 exept the 4th gear is higher giving a bit more speed.The 185 kit pulls the 4th gear without a problem and I've had the gearbox for quite a few years without any issues.
