End can
End can
Postby Stevepshipley » Fri May 12, 2017 10:45 am
Just noticed (it may have been happening for ages) the internal part in the endcan on my TSR evo spins a bit when I rev it. The part behind the big circlip at the back. Should I be worrying about this?
Stevepshipley
Re: End can
Postby rossclark » Fri May 12, 2017 11:13 am
Does suggest there might not be much wadding left in the can...
Has it got noisier recently?
Re: End can
Postby Stevepshipley » Fri May 12, 2017 11:23 am
Err, yes possibly. Should I take it apart and see? Only done about 1000 miles I reckon, why would it lose wadding.
Stevepshipley
Re: End can
Postby holty » Fri May 12, 2017 11:41 am
the wadding is usually fibreglass wool in it gradually gets burnt up and expelled out of the exhaust, ive got wire wool in my exhausts to stop this happening, bought a large bag of it from b+q :D
holty
Re: End can
Postby Stevepshipley » Fri May 12, 2017 12:05 pm
Nice one thanks guys, does wire wool have the same noise deadening effect ?
Stevepshipley
Re: End can
Postby Rich Oswald » Fri May 12, 2017 12:07 pm
I have just replaced the wadding on my Taff Mk 4 (similar can) and mine spins but probably because the circlip was tack welded on and I had to dremmel it to remove it. Done quite a few miles since without detriment, in fact it probably uses the wadding more evenly.
Re: End can
Postby Toddy » Fri May 12, 2017 3:02 pm
This stuffs ok , don't pack it too tight though
http://www.ebay.co.uk/itm/181633559294? ... EBIDX%3AIT
Re: End can
Postby Stevepshipley » Fri May 12, 2017 3:42 pm
I'll try that then. Thanks chaps, sound advice as always
Stevepshipley
Re: End can
Postby Rich Oswald » Sat May 13, 2017 7:59 pm
Toddy wrote:This stuffs ok , don't pack it too tight though
Yhat's what I used
Re: End can
Postby gaz_powell » Sun May 14, 2017 2:25 pm
You need to sort it, I had this and left it for a while, eventually the movement cut through the tail pipe behind the circlip and the end came off with baffles etc flying out behind me on route to Llangollen last year (on A19 flyover.
Repack it and tack it the plate to the circlip.
I've just returned form C2C and mine on the Taff copy need doing as it spinning and rattling like a good en!!
Re: End can
Postby Mel K » Sun May 14, 2017 5:53 pm
https://www.scooterlab.uk/wp-content/up ... 796800.jpg
A get you home bodge for a spinning end can :idea:
Mel K
Re: End can
Postby gaz_powell » Mon May 15, 2017 9:06 pm
gaz_powell wrote:You need to sort it, I had this and left it for a while, eventually the movement cut through the tail pipe behind the circlip and the end came off with baffles etc flying out behind me on route to Llangollen last year (on A19 flyover.
Stripped my end can tonight and the wrap was brittle and in pieces. Repacked it, alll good, just didn't have time to put a little little weld on the cap/circlip
Re: End can
Postby Stevepshipley » Tue May 16, 2017 3:47 pm
Stripped and repacked, relatively straightforward job for a lambretta. Many thanks thanks for the advice all. Cheers steve
Stevepshipley
Users browsing this forum: Baidu [Spider] and 61 guests
