Heat sink
Heat sink
Postby jonno » Wed May 10, 2017 5:00 pm
Would a heat sink on the exhaust near the exhaust port be of any benefit on a 2 stroke?,clearance issues aside on Lammy of course.
jonno
Re: Heat sink
Postby Scooterlam » Wed May 10, 2017 6:00 pm
Depends on what you want to achieve
Many like mild steel pipes as they run hotter. My old clubby used to pick up when I got some heat build up.
Scooterlam
Re: Heat sink
Postby jonno » Fri May 12, 2017 4:16 pm
Well i dont know if its connected with heat build up,but the honing marks have worn away around the exhaust port.Was wondering if excessive heat had contributed?
jonno
Re: Heat sink
Postby Fast n Furious » Fri May 12, 2017 4:25 pm
What type of cylinder are you using here?
Re: Heat sink
Postby jonno » Fri May 12, 2017 10:14 pm
Its a steel lined TS1
jonno
Users browsing this forum: TrackTen and 61 guests
