GP taper lightened Flywheel off the shelf
Postby berniek » Sun Apr 30, 2017 9:09 pm
Hi all, just putting an engine together for someone for the euro. Their previous flywheel is 2.8 kg and I'm looking for about 2.0 kg. I know I can get lightened, and a few offer this service. What I'm after is advice on what is available off the shelf to go with a "standard" electronic type stator (not variotronic or casatronic stators). Who sells off the shelf, and are they modified Indian or something different? Thanks
berniek
Re: GP taper lightened Flywheel off the shelf
Postby steve c » Sun Apr 30, 2017 10:17 pm
beedspeed did them, they just turned material off the diameter in rings from indian flywheels beware of elmec dark grey paint unless with a matching stator
sil are better but you can still have trouble matching pick up height between parts,
steve c
Postby dscscotty » Sun Apr 30, 2017 11:23 pm
Send it up here Bernie, we'll machine it and weld cam?
Postby Fast n Furious » Tue May 02, 2017 5:05 pm
AF do a machined down indian flywheel both the short and long finned type. I think they call it a "midrange weight". They weigh circa 1.8kilo's. They are not re-balanced though.
Postby gaz_powell » Tue May 02, 2017 7:10 pm
Bernie if a genuine SIL send it to Scotty for lightening and welding - defo worth it
