coaster wrote:I didn't realize that Ron did a reed valve piston or I'd have bought one last year when I reed valved my Avanti TT3. What I did was use a TS1 piston as a pattern to mark and cut windows into the Avanti piston skirt as well as the cut away at the bottom. The windows lined up well with the Avanti inlet so I would image the same would be true in reverse. Also, a single oval window is likely to flow better than 2 windows as per the TS1 I would think.
Scooterlam wrote:coaster wrote:I didn't realize that Ron did a reed valve piston or I'd have bought one last year when I reed valved my Avanti TT3. What I did was use a TS1 piston as a pattern to mark and cut windows into the Avanti piston skirt as well as the cut away at the bottom. The windows lined up well with the Avanti inlet so I would image the same would be true in reverse. Also, a single oval window is likely to flow better than 2 windows as per the TS1 I would think.
pretty sure Rons ts1 pistons wont fit a reed Avanti,
gaz_powell wrote:So what grade Avanti piston did you use against grade on TS1 barrel?
gaz_powell wrote:Cheers Ian, I was just looking for a straight replacement in my B barrel.
