Paul_from_Thornbury wrote:Bluebob, mine was almost identical to you. My original build and my second build after a failed ring peg were at a final ration of 5.21, a 15 tooth standard front sprocket, 46 tooth clutch sprocket and standard Italian Li150 box, with an MB clubman, and as you say its a very revvy engine in that config. Just looked at the gearbox calculator online and yours is at 5.3, so its going to be even more revvy than mine was.
Just built with my meteor piston and put a 16 tooth front sprocket to come down to 4.89, and its much better and could probably even do one more step to a 17 tooth. You will come down to 4.98 with a 17 tooth, and 4.70 with an 18 tooth.
I'm going to leave as is for now as its nice to have the revs there when you want them rather than coming down another stage, but I would definitely put in a 17 tooth in yours.
Google 'Lambretta Gearbox calculator', it comes up on a scooter help webpage, you just plug in your settings and it shows the ratios and speeds in each gear at different RPM.
Users browsing this forum: TrackTen and 62 guests
