Carb clearance
Carb clearance
Postby Blaginit » Fri Mar 24, 2017 7:58 pm
Hi all need advice GP frame and engine with ts1 fitted I'm concerned how close carb 30 mm deli phbh fitted is to side pannel looking for a quick fix would a fixed mount to manifold and rubber mount to carb give me any extra clearance if so how much that's if it would give me any advantage at all or as any one a better solution please help
Blaginit
Re: Carb clearance
Postby al pushpak » Fri Mar 24, 2017 9:53 pm
Hi, on my GP i run a 30mm dellorto on a ts1 & i use one of the readspeed, just Lambretta, lth etc, shortened type with the bolt on rubber , which gives about 10mm clearance under the panel, i also managed​ to fit an air hose & remote filter under there as well ! hope this helps ;)
al pushpak
