I'm hoping that chipping a bit off the spigot isn't terminal. Any advice? Or do I need to throw it away?
foremanbob wrote:The most common way of doing that is in removing the gudgeon pin with the piston partially inserted.
There are a few threads about detailing it if you search. I did the same with a TS1...
The concensus was clean up the broken edge with a dremel to smooth it off and radius the corners. and it should run OK
The skirt supports your piston, but since such a small percentage of total surface area is missing it should be OK.
gaz_powell wrote:oh dear TGS
Agree with others clean it up, radius, chamfer etc and fit it ...........
Did you do the stud holes ?
Bit of a scud this barrel for you !
Remember ..... she's smooth on the curves, never gets on your nerves..... Laaaaaambretta, Laaaaaaambretta
Gaz
