Fast n Furious wrote:Hmmmm... I've considered this one as well Simon.
They are not cheap and I've gotta wonder what advantages you get with this product compared to those alternatives around £100 cheaper?
Warkton Tornado No.1 wrote:Fast n Furious wrote:Hmmmm... I've considered this one as well Simon.
I wondered that too, but perhaps the rebound & compression adjustments (both slow & fast) might be truly independent of one another![]()
I’m not sure of that being the case with any other, but apologise in advance for my lack of knowledge....
a-teamlambretta wrote:thinking about getting one of these http://www.pmtuning.co.uk/lambretta-pro ... rear-shock , anyone using one pro's con's ect . cheers simon
dickie wrote:Warkton Tornado No.1 wrote:Fast n Furious wrote:Hmmmm... I've considered this one as well Simon.
Independent high and low speed damping? Are you serious? Carl fogarty didn't need it to win several world championships do you really think you do to call round the shops?
It is listed in the specification sheet by PMTuning.
If you have an issue with that, perhaps you should direct your comments elsewhere, as I was not advocating the PMTuning shock absorber over any other.
If I were to state an opinion, I would perhaps dare to suggest that the young Italian riders manage to hustle their scooters around a racetrack at unprecedented rates & it may be worth looking @ their suspension set up as they have something that works well with the scaffold tubing that forms the basis of our frames.
Leotech wrote:
I think you'll probably find Carl Fogarty did have high and low speed compression damping adjustments on his rear shock.
