Exhaust question
Exhaust question
Postby St George » Sat Feb 18, 2017 6:21 pm
What are the pros and cons of having a two piece U bend joined together with springs, do they seal well or is sealant required. Have scootopia in mind. Thanks
St George
Re: Exhaust question
Postby Adam_Winstone » Sat Feb 18, 2017 6:26 pm
Additional scope for movement and fitting so that it is not stressed means less chance of it cracking. If you then throw into the mix the differences in engine component, it simply means that it is more likely to fit (again, more adjustment).
Postby St George » Sat Feb 18, 2017 6:37 pm
Thanks Adam, do they seal on the joint well.
St George
