by stephena » Sun Feb 05, 2017 11:36 pm
Thinking of fitting a scootopia 42mm clubman to gp 125 with a 150 top end. The question is will I find much improvement in performance and will I need to rejet the carb. Thanks any help appreciated.
stephena
by rossclark » Mon Feb 06, 2017 12:13 am
The 150 will pull a bit better than a 125, the exhaust will let it meet on a bit better still.
You should check your jetting with a few plug chops as it likely will need adjusting.
by stephena » Mon Feb 06, 2017 8:50 am
I already have the 150 top end on reading my post that wasn't perhaps clear. The original exhaust is looking a bit batterd and I have only read good reports on the scootopia one so hope they are worth a try.
stephena
Users browsing this forum: Bing [Bot] and 64 guests
