corrado wrote:Mine and the general consensus is that they're fine as standard. BGM clutch cable on mine.
Fast n Furious wrote:............Similarly the clutch lever on the handlebars suffers enormously from wear around the pivot point............I opted to drill my old worn housing out to accept 2 flanged mini bearings. ............Standard levers are a bit tosh. A better leverage ratio can be obtained using Japanese motorbike levers. There are hundreds of different levers available..............I used a yammy SR125 lever which required a bit of fettling and admittedly isn't a perfect fit but is has good leverage and is very comfortable. The leverage hole was the wrong size for the Lammy bolt but this was soon sorted by drilling out and fitting the right size of bearing in the lever itself. So my clutch lever has 3 bearings in it. No slop and a really smooth action.
Fast n Furious wrote:When you look at everybody else's scoot at rallies (as ya do), I notice on those without panels, the angle of the clutch slave actuating lever (the bit where the trunnion fits).
If its not set correctly (one notch left of centre), the master/slave ratio is adversely affected.
I also notice the same boob with the rear brake cam lever set up, and folk wonder why their rear brake is crap?
You must have to stand on some of them!
