jetex atomiser mods
jetex atomiser mods
Postby neil64 » Fri Jan 27, 2017 1:07 pm
hi ,
anyone got any details of the 5899-2 atomiser modications to richen up mid range . any help would be great .
cheers.
neil64
Re: jetex atomiser mods
Postby Rich Oswald » Fri Jan 27, 2017 1:24 pm
neil64 wrote:hi ,
cheers.
Pretty sure you just drill the centre hole down the tube to 2mm but then again an adult may be along soon to contradict that :shock:
You could buy them ready done from Allstyles, not sure if you still can.
Postby EddieStone » Fri Jan 27, 2017 1:33 pm
Can't claim to be an adult.
If you want to richen the mid range you need smaller holes, not larger.
EddieStone
Postby Rich Oswald » Fri Jan 27, 2017 3:16 pm
That's brilliant, i'm saving that. So really if he needs to richen the mid range he needs a 5899-4 then (smaller mid-range holes) ?
Postby St George » Fri Jan 27, 2017 6:34 pm
I thought Delly jets fitted those carbs ?
St George
Postby HxPaul » Fri Jan 27, 2017 6:49 pm
They do.
Postby sunrisemac » Fri Jan 27, 2017 8:27 pm
Not quite as simple as that, the other holes in 5899-4 are different to 5899-2 so they will have an impact other areas of throttle opening
sunrisemac
Postby Rich Oswald » Sat Jan 28, 2017 9:54 am
Got ya!
Postby TS1-200 » Sun Jan 29, 2017 7:19 pm
Whatever you decide don`t try drilling, its not as easy as it sounds
TS1-200
Postby sunrisemac » Sun Jan 29, 2017 7:43 pm
TS1-200 wrote:Whatever you decide don`t try drilling, its not as easy as it sounds
I agree, jet reamers are the best option for changing jet and hole sizes in carbs
sunrisemac
