175 info
175 info
Postby P D: SC Chester » Sat Jan 14, 2017 10:40 pm
I'm in the process of rebuilding after a bump. Have fitted an AF 175 cylinder and asso piston to match. The cylinder is supposedly a stage 4.
What sort of performance can I expect as a ball park top speed and acceleration?
Set up is also sterling exhaust and either a 22mm through air box or 28mm Mikuni with remote.
As a standard GP150, top speed struggled over 45.
P D: SC Chester
Re: 175 info
Postby missing lynx » Sat Jan 14, 2017 10:50 pm
I would have thought a top speed of 60-65 mph with a bit brisker than std acceleration as long as the transfers and inlet manifolds are blended
Re: 175 info
Postby P D: SC Chester » Sat Jan 14, 2017 11:12 pm
Sound, cheers
P D: SC Chester
Re: 175 info
Postby missing lynx » Sat Jan 14, 2017 11:30 pm
on that setup I would use the 22 the bigger carb will just use more fuel for little to no advarntage
Re: 175 info
Postby CHRIS in MARGATE » Sun Jan 15, 2017 10:03 am
I think the anticipated 65mph will be the Lambretta speedo reading, not the actual speed. I'd subtract 10 from that.
Re: 175 info
Postby P D: SC Chester » Sun Jan 15, 2017 10:49 am
I quite like the dancing needle :)
P D: SC Chester
Re: 175 info
Postby ToBoldlyGo » Sun Jan 15, 2017 1:03 pm
CHRIS in MARGATE wrote:I think the anticipated 65mph will be the Lambretta speedo reading, not the actual speed. I'd subtract 10 from that.
I think that's probably about right. Mind you a steady 55mph is nothing to be sneezed at. It's actually pretty good going.
Re: 175 info
Postby Jim Rose » Mon Jan 16, 2017 7:52 am
I'm running a barrel like yours with a PM pipe and a 30mm. Done a lot of miles on it but it maxed out at 60 mph with the wind behind it. I opened the exhaust pot 2 mm higher and it was going comfortably at 65 mph on the auto bahns to Austria but it is thirsty!
Good luck
Jim Rose
Re: 175 info
Postby EddieStone » Mon Jan 16, 2017 10:03 am
I run a 175 - it's been ported a bit and I flowed the inlet manifold to the port. Running a 20mm carb through an airbox with the baffle in it and a 42mm clubman.
I changed the front sprocket (standard Li150 Series 3 gearbox) to a 17 and it pulls well, and hold 60 on the flat on a dual carriageway, measured by GPS. Feels like it would rev a bit higher, possibly if I took the baffle out of the airbox so it may touch 65mph, but not sure if it would hold it on the flat. .
Starts easily and returns about 70mpg ridden in a lively fashion. I really like 175s.
EddieStone
Re: 175 info
Postby Phil D » Mon Jan 16, 2017 10:31 am
I really like 175s.
+1
Phil D
Re: 175 info
Postby P D: SC Chester » Mon Jan 16, 2017 5:14 pm
Real men drive 175's :D
P D: SC Chester
Re: 175 info
Postby a-teamlambretta » Mon Jan 16, 2017 5:41 pm
you dont have to pretend to be having a smoke in a layby either ( ts1 blown up ) :lol:
a-teamlambretta
