Yam piston
Yam piston
Postby betty2015 » Wed Jan 11, 2017 11:30 am
Hi lads were would i buy a first over size 64mm yam piston
betty2015
Re: Yam piston
Postby Warkton Tornado No.1 » Wed Jan 11, 2017 1:11 pm
Good quality, affordable components that your Tuner probably prefers you don't know about:
Grampian Motors: http://www.mitaka.co.uk/index.html
However, you might check the 'steps' of over-sizes as the OEM Yamaha pistons used to be in increments of 0.25 mm whereas pattern pistons might only go in 0.5 mm variations. There are NOS items on eBay.
This one looks OEM @ Ø64.25 mm:
272510496938
I hope that information helps ;)
Re: Yam piston
Postby betty2015 » Wed Jan 11, 2017 4:52 pm
Thank you
betty2015
Re: Yam piston
Postby bazza3004 » Fri Jan 13, 2017 1:37 am
Ive used 'yambits' a few times for pistons and always found them good to deal with.
bazza3004
Re: Yam piston
Postby Fast n Furious » Sat Jan 21, 2017 1:36 am
If its the Banshee piston, you may have problems with the 2nd ring peg position. With some cylinders it will drop over the inlet port.
Users browsing this forum: Bing [Bot] and 65 guests
