Spare piston 186 muggy
Postby Marty ULC » Tue Jan 10, 2017 2:13 pm
Want to carry a spare piston for the mugello 186 I'm taking to Adria.
Seeing as it's just a get me home thing would a KAC or other standard (ie cheap) type 64mm piston work okay or does it have to be an expensive mugello one?
Chances are that the barrel will be damaged if the piston goes anyway so don't want to waste too much money.
Marty ULC
Re: Spare piston 186 muggy
Postby Warkton Tornado No.1 » Tue Jan 10, 2017 5:10 pm
Hmmm. I can see why you're asking @ 100 quid cost.... :(
Mugello use Graded pistons, so you really need to establish which Grade you need to establish the actual size/tolerance based upon the nominal diameter.
You might then be able to select an alternative but I think you’ll be lucky...
There may be lots of ‘cast-offs’ available via the members of this Forum, though, so it may be worth asking once the Grade has been established.
BTW. Bear in mind that whatever piston you may opt for, the rings need to be suitable for a plated bore.
It may be the best option to take a spare, cheaper cylinder kit just to get you home. The chances are, you probably have one knocking about, already... :)
Postby Marty ULC » Wed Jan 11, 2017 1:15 am
Thanks WT1
Marty ULC
