varietronics
varietronics
Postby rexton270s » Fri Dec 23, 2016 7:40 pm
does anyone with varietronics know if theres a power take off the regulator to power a pluging for a phone charger ?
rexton270s
Re: varietronics
Postby Donnie » Fri Dec 23, 2016 9:14 pm
rexton270s wrote:does anyone with varietronics know if theres a power take off the regulator to power a pluging for a phone charger ?
Nope, the regulator 4th pin is for powering a battery (trickle charge only) or you can probably use a modcharger (Google is your friend) but I don't have one of them so have no idea if that will have a decent output to charge a phone
Donnie
Re: varietronics
Postby jonashford » Sat Dec 24, 2016 7:36 am
fit a battery to run ur gadgets, then trickle charge the battery, works very well
jonashford
Re: varietronics
Postby Knowledge » Sat Dec 24, 2016 7:55 am
jonashford wrote:fit a battery to run ur gadgets, then trickle charge the battery, works very well
That will be a burglar alarm sealed battery. Cheap, safe and easy to fit. Check out the dimensions on the PDF fact sheet on the Yuasa website.
Re: varietronics
Postby Jim Rose » Sat Dec 24, 2016 9:34 am
Thanks Martin just what I need. I've been putting my variatronic through a bike battery that runs sat nav and phone charger really well. I need something smaller for the project. Any particular battery you suggest?
Jim Rose
