Stainless exhaust
Stainless exhaust
Postby Cellardyke » Tue Nov 22, 2016 9:46 am
Pros and cons on using stainless exhaust ? Any advice or experiences on using scootrs stainless exhaust would be appreciated
Cellardyke
Re: Stainless exhaust
Postby CHRIS in MARGATE » Tue Nov 22, 2016 10:26 am
Had mine on for 6 years or so. Been good. Still looks new. Had to re-rivet end can couple of years back. I discarded the rubber mountings and bolted straight on but NOT under any tension after altering mounting holes on support bracket. Flywheel side downpipe nut difficult to get good access to due to design. Shaped a tight open ended spanner and use this with 3 or 4 others to get tight.
Overall pleased.
Postby Cellardyke » Tue Nov 22, 2016 10:41 am
Chris,
What are you riding ? I've a series 2 and wondered how much trimming I will have to do around footboards..
Cheers for the response.
Cellardyke
Postby CHRIS in MARGATE » Tue Nov 22, 2016 6:39 pm
Series 3 Special. Needed to cut a small oval at the rear of rear running board. You can see it here on my avatar.
Postby Cellardyke » Wed Nov 23, 2016 10:39 am
Cheers Chris... In sunny Margate
Cellardyke
