tuning & kits
tuning & kits
Postby rexton270s » Mon Aug 08, 2016 1:43 am
question? the tv175 had a 116 conrod opposed to the 107 rod! you can buy small casing kits without using packers to suit the rod !(mugello) so i was wondering why there are no large casing kits that are made for the 116 rod without using packers? ie bolt on and go without any modifications?
rexton270s
Re: tuning & kits
Postby MickYork » Mon Aug 08, 2016 7:04 am
I'm guessing the barrel would be matched to the 116 rod, ie the port timings would be set higher to match the longer rod......
Re: tuning & kits
Postby dickie » Mon Aug 08, 2016 7:54 am
Or lower crown height. Isn't the rb22 such a kit?
Re: tuning & kits
Postby dscscotty » Mon Aug 08, 2016 8:45 am
RB 20 @ 66mm requires a 116mm rod
Re: tuning & kits
Postby rexton270s » Tue Aug 09, 2016 10:18 am
rb20 is a small block kit! never thought of the rb225 being a bolt on 116 rod kit!
rexton270s
