Piston circlip broke and went up the side of the piston
Can this barrel still be salvaged and used and if so what is the best way to do it?
As you can see the only real damage is to the boost port edges, can I just smooth these with a dremmel?
Re: TS1 salvageable?
Post by bsso78 » Tue Jul 26, 2016 1:17 pm
Stick a new piston up it and thrash the knackers off it.
Post by coaster » Tue Jul 26, 2016 3:37 pm
Just a gentle clean up with some 240 grit wet & dry with your finger will be enough
Post by berniek » Tue Jul 26, 2016 2:29 pm
it will be fine, no issues. if you don't believe me (and those above) then I will happily take it off your hands for £50!
Post by gaz_powell » Tue Jul 26, 2016 1:48 pm
I`ve been running one for years that's worse than that - I check it every year and always expect a problem, but it hasn't got any worse and has done more miles since it was damaged than before.
As already said - Quick clean up to make sure no bad edges and a new piston.
If your worried you get a new one and send it to me I`ll make use of it !!
Gaz
bsso78 wrote:Stick a new piston up it and thrash the knackers off it.
