Which Strobe?
Which Strobe?
Postby Wee Mark » Wed Jul 20, 2016 9:30 pm
Hello Gents
I need to strobe my timing as I have fitted a lighted flywheel and have no idea which type of Strobe light to buy or the difference between them, whats best for Lambretta use in your experience?, its a Rapido Classic 225 Kit and AF light flywheel i'm running so posted in this section...
Wee Mark
Re: Which Strobe?
Postby rossclark » Thu Jul 21, 2016 12:38 am
I got a power spark one off eBay for about 15£ you need a battery to run it but worked fine on mine.
Re: Which Strobe?
Postby Toddy » Thu Jul 21, 2016 6:12 am
I have the Draper one, had it for a few years now , also needs a battery
https://www.amazon.co.uk/Draper-52616-X ... B0001K9V3Q
Re: Which Strobe?
Postby HxPaul » Thu Jul 21, 2016 8:51 am
I've got a cheap one off Ebay.It has 2 leads,one you plug into the mains and the other fastens on top of the plug.
Re: Which Strobe?
Postby drivera » Thu Jul 21, 2016 9:04 am
Toddy wrote:I have the Draper one, had it for a few years now , also needs a battery
Same here good unit and easy to use , I made a power pack from an old 12v DC charger
drivera
Re: Which Strobe?
Postby EddieStone » Thu Jul 21, 2016 9:07 am
I use one of these: http://www.ebay.co.uk/itm/AccuSpark-H80 ... Swkl5XcoDm
Needs a 12V battery, but gives a bright light and is well made. And cheap. The pick up lead is plenty long enough to clip on the HT lead and allow you to point the gun at the flywheel.
EddieStone
Re: Which Strobe?
Postby CHRIS in MARGATE » Thu Jul 21, 2016 9:13 am
Be mindful that the pick up may be directional and have printed on it something like "spark plug this side".
Re: Which Strobe?
Postby johnnyXS » Thu Jul 21, 2016 9:44 am
I'd be surprised if you can get a consistant reading with a lightened flywheel because the engine won't have its usual dampening effect of the heavier ,'normal' weight flywheel.
I've recently bought a Gunstons tachostrobe like this one but I've yet to try it out so afraid I can't recommend it
http://www.ebay.co.uk/itm/GUNSON-TACHOSTROBE-XENON-TIMING-LIGHT-WITH-ALL-PAPERWORK-/322195233808?hash=item4b04551c10:g:l2UAAOSwYqxXi3kU
johnnyXS
Re: Which Strobe?
Postby dave81 » Thu Jul 21, 2016 5:09 pm
I bought the Accuspark strobe on Ebay as well. I stood the scooter in front of my car and put the supply leads on the car battery. I was surprised how much difference there is on timing between static and strobe timing.
dave81
Re: Which Strobe?
Postby steve t » Thu Jul 21, 2016 8:38 pm
I also have accuspark of eBay works ok I've used a car battery or even a 12v battery charger you get the same results as a £200 snap on strobe I borrowed of a mate
steve t
Re: Which Strobe?
Postby Paul_from_Thornbury » Wed Aug 03, 2016 1:18 pm
not seen these in the UK but I'm sure they're available, picked mine up in USA, runs off two D size batteries, cost me about £30
http://www.oreillyauto.com/site/c/detai ... &ppt=C0103
Paul_from_Thornbury
