Atomic Reed Valve on Rapido
Postby CHRIS in MARGATE » Mon Jul 04, 2016 10:19 pm
Too much spitback on my current set up so I want to reed valve a 225 Rapido I bought last year.
Just drilled 2 holes in a holed piston without problems so no worries there.
What is the difference in performance between the Atomic Mini and Atomic full size assembly ?
How big a carb will they accept ? I normally use my Koso 30mm which has an external spigot of 38mm and I have another new 30mm Koso power jet with a 34mm external measurement across the spigot.
Any advice gratefully accepted as I come into the 21st Century.
Re: Atomic Reed Valve on Rapido
Postby gerryjunior » Tue Jul 05, 2016 8:53 pm
gerryjunior
Postby CHRIS in MARGATE » Tue Jul 05, 2016 9:04 pm
Thank you for taking the time to answer, it is appreciated.
I have read this several times so I guess my next question to the membership is: who is using a Shorty and how does it sit ?
