Achieving more top end w/out changing the gearbox
Postby swissdean » Tue Jun 28, 2016 2:44 pm
Have put a Casa 185/Ancellotti etc on a Serveta lince 125...but it seems to go slower than with the 125 barrel!
Not wishing to go backwards (literally!) is this possible to improve by changing front and rear sprocket/clutch case and if so what would you recommend.
I am not sure what gearing ratios I am starting with as info on line is scant (Its an '86, serveta 125 lince if anyone would know)
Dean
swissdean
Re: Achieving more top end w/out changing the gearbox
Postby Vmakgp » Tue Jun 28, 2016 3:58 pm
I'm just looking at the Granturismo Gt data & Richard recommends going up to an 18 tooth primary with 82 link chain with ya standard 46 crown wheel , sticky book says 46 x 18 - with a stretched 81 link chain .
Hope that's of some use .
Vmakgp
Postby swissdean » Tue Jun 28, 2016 5:38 pm
thanks, that sounds like a simple fix, will give it a go
swissdean
Postby Bofs » Tue Jun 28, 2016 7:34 pm
Stick a 4.00 x 10 tyre on the back, will upgear it a bit too. Maybe another 5mph in top.
Bofs
Postby HxPaul » Wed Jun 29, 2016 10:13 pm
swissdean wrote:Have put a Casa 185/Ancellotti etc on a Serveta lince 125...but it seems to go slower than with the 125 barrel!
Dean
No matter what the gearbox is,with a Casa 185 top end it should go a lot quicker and be more powerful than it was with the original 125 top end.If i were you I would look elswhere for the problem,if the top end is all that you have touched,thats where I would start looking.
