Electrix stator wiring
Postby Leggetto » Fri Jun 17, 2016 11:56 pm
I am finally getting round fitting my Electrix electronic kit and I'm struggling with the wiring.
The stator has six wires a white red and green that goes to the cdi
I am now left with 2 yellows and a white all with female bullet connectors??????
I am used to seeing 1 yellow to the rectifier but not this...
I am running a basic loom and need a single ac power for the lightsand No battery fitted!
I read somewhere that the stator is 3 phase so do I join all 3 wires together parallel or in series???
Anybody????
Thanks Paul
Leggetto
Re: Electrix stator wiring
Postby Leggetto » Sat Jun 18, 2016 10:06 pm
All sorted thanks to Neil at Brolam.
Join the 2 yellows together and connect to the ac side of the regulator.
White wire to earth
Lights are better than average on tick over and proper bright at anything over 1200rpm
Leggetto
Postby Leggetto » Sat Jun 18, 2016 11:44 pm
I thought this had advance retard built in but when we set it up it was static!!!!!
Leggetto
Postby Leggetto » Sun Jun 19, 2016 8:57 am
I'm going to give Brolam a call on Monday to check as I'm off to the euro on Wednesday and don't want to get out!
Do you know how the ignition is advance retarded on this kit? Is it in the cdi or the stator itself.
If it is static can I use a Ky- tronic or similar???
Leggetto
