top end
Posted:
Sun Jul 06, 2014 11:47 pm
by 59 lammy boy
What 185 top end would you recommend for a small block?
I don't want to buy the £70 kits off eBay and I haven't got the money for the gt kits
What I'm looking to buy is something in between that is a good reliable head and barrel kit with good clean transfere posts etc
Re: top end
Posted:
Mon Jul 07, 2014 6:25 am
by Toddy
Most of the decent 185-200 small block kits are between £400-£550 plus the extras you may need to fit , you may be better looking for a second hand one or try
getting your esxisting set up ie 150 tuned and ported by a reputable dealer .
Re: top end
Posted:
Mon Jul 07, 2014 9:46 am
by Donnie
Agree there, you're looking at decent money for most upgrades from a 150, unless you go for a half decent 175 thats been sorted properly, or the other alternatives a suzuki conversion second hand, you should pick one up for less than £100 if you can find one.
Re: top end
Posted:
Mon Jul 07, 2014 1:40 pm
by corrado
Harry Barlow usually has some sorted sub 200 kits at Wicksteed for decent money, Suzuki etc. He's worth having a chat with.
info@pro-porting.com0116 2871285
Re: top end
Posted:
Mon Jul 07, 2014 4:31 pm
by Rich Oswald
There are some 185 Alloy kits that some dealers are re working to make them usable. I think Buzz Solomoto does this. A few people have had good results from them.
Re: top end
Posted:
Tue Jul 08, 2014 7:28 pm
by Steve J
Isn't one of the problems with the cheap 175/185 alloy barrels with iron liner that the liner itself is soft, and wears fairly quickly?
Re: top end
Posted:
Tue Jul 08, 2014 8:20 pm
by Storkfoot
Steve J wrote:Isn't one of the problems with the cheap 175/185 alloy barrels with iron liner that the liner itself is soft, and wears fairly quickly?
Yes, but in my experience it also depends on the rings. I had one set of rings which were totally destructive to an SR barrel whereas a Racetour piston and rings were relatively OK
Re: top end
Posted:
Fri Jul 11, 2014 3:57 pm
by lofty
there was a massive thread on the old forum about the 'SR' kits and how they can be made to work..
however you will need to be handy with the dremel or pay someone who is handy, I run one on my TV175 and it works very well (touch wood!!)..
alternatively just get an iron barrel bored, ports opened and use a clubman and 22+mm carb, it will give a reasonable boost to performance at a moderate cost..
Re: top end
Posted:
Fri Jul 11, 2014 5:35 pm
by Scooter Paul
On a tight budget I'd agree with Lofty. Get the original barrel bored to 175 with ports matched to manifolds and use a quality clubman and a sorted 22mm Jetex.
Paul
Re: top end
Posted:
Fri Jul 11, 2014 5:49 pm
by MickYork
Get your casings sorted to take the 200 stud configuration (costs £150 ?) then use a stage four 200 barrel and piston (£100 ?).
Re: top end
Posted:
Sun Jul 13, 2014 2:58 am
by 59 lammy boy
Thanks for all your help and advise.
I have now bought a very good second hand imola 186 kit
Re: top end
Posted:
Mon Jul 14, 2014 7:37 pm
by bluebob
just following mickyork,s comment about casings,the old forums had some good threads on this,recall there was a good video clip aswell.anyone got any recommendations for the work.
cheers
Re: top end
Posted:
Mon Jul 14, 2014 7:52 pm
by MickYork
There you go. Oiltek, based in South Yorkshire
https://www.youtube.com/watch?v=E3EmdUUFpzc
Re: top end
Posted:
Mon Jul 14, 2014 7:59 pm
by bluebob
nice one mick
