MickYork wrote:The scooter will run, but at high rev's you may empty the bowl too quickly and risk holing the piston. Not worth the risk unless you're just pottering around town.
Would an off-set 90" adapter on the choke help ?
by Stevepshipley » Thu Jun 16, 2016 9:26 am
Thanks for the input, I'm fairly certain the main problem is with the manifold. I think I fitted one of the originals which I seem to remember were problematic. I've since found an AF manifold and a more recent mugello manifold. Plan is to try one of these together with a 90 degree cable adaptor when I get time.
Thanks much appreciated
Steve
