Post by Wack » Wed May 18, 2016 5:37 pm
I've seen Rapido's leak around the liner to alloy joints and also up the cylinder studs as there's not a lot of gasket face between the lower stud holes and the transfers.
I've just put 200 miles on my 225 Rapido Classic with new piston after its winter rebuild.
PSC GP200 » Fri Jun 17, 2016 10:41 pm
I've got a few more miles on it now and I think it may be carb related as it pinks at about 5k rpm/half throttle. You can ride into and out of the weak (?) area. When it starts to pink open the throttle fully stops it and as you come back down you re enter the weak area.
Is adjusting or changing the needle position the best way to eradicate this?
Wack wrote:I've seen Rapido's leak around the liner to alloy joints and also up the cylinder studs as there's not a lot of gasket face between the lower stud holes and the transfers.
Users browsing this forum: Bing [Bot] and 54 guests
