Mugello 225 cylinder head hexagon nuts
Postby Strummer10 » Mon May 09, 2016 11:11 pm
Hi All, We have just been working on a Muggy 225 tonight. Had to rub the head of the barrel down to get to a squish of 1.45 but noticed we had a problem tightening up the 3 hexagonal bolts. It seems to me the threads are not long enough ??
Has anyone had this problem and knows the resolution, I would say the threads need to be another 10 mms longer, maybe even 15mm's as they were turning and not tightening up. The actual bolts are 57.4 mms long, of which 22.8 mms is the thread
Strummer10
Re: Mugello 225 cylinder head hexagon nuts
Postby Strummer10 » Tue May 10, 2016 7:48 am
Will ring Cam Lam today and see if we have the right bolts maybe.......
Strummer10
Postby Strummer10 » Wed May 11, 2016 8:46 am
Problem solved, just use the longer inlet manifold studs with nuts and washers to bite down into the threads....
Strummer10
