casatronic in a RB 225
Postby dale61 » Mon May 09, 2016 4:35 pm
Hi just about to fit a casatronic to my RB and would like to know initial timing at tickover? anybody? Thanks Dale.
dale61
Re: casatronic in a RB 225
Postby Knowledge » Mon May 09, 2016 5:21 pm
Welcome to the forum, Dale.
I am unfamiliar with this kit, but I feel obliged to ask if there were any fitting instructions with the kit? If not, you have to ask why not?
If there are instructions for setting up a standard engine, and your question is more to do with "what setting should I use for my non-standard engine", initially I would set it up as standard if only to prove that the kit works. You can then fettle it a little to suit the RB, based on feedback from others.
It is quite hard to hurt an engine at tick-over speed, even if it is not quite the right timing, so perhaps just prove that the Casatronic kit works (I'm not implying that Casatronic kits don't work)
Martin
Postby dscscotty » Mon May 09, 2016 6:34 pm
I normally set the up around 23 BTDC @ tick over, my own preference is to have them running at around 17'-16'-BTDC at cruising speed between 6500-7000rpm depending on gearing, pipe -set-up etc, then retarding to say 15'BTDC 7000-8500 if the motor will rev that high. I'm not to bothered at what its doing at tick over more at what its doing at higher rpm. I use the CASA Vari-tronic on both my road motors and have fitted several others a great piece of kit imho.
Here's a link that may help you
https://www.youtube.com/watch?v=x2-VTMsfdBA
Good luck
Postby dale61 » Tue May 10, 2016 10:23 am
Thanks for your replies guys, Martin there are instructions with kit and a video on you tube on how to fit them and they are a very nice bit of kit it was that I was just unsure as where to start from as a base setting to get the timing right for cruising ect which has been explained so now happy bunny. Many thanks again for your replies
dale61
