Leak-down testing on the cheap
Postby Sticky » Sun May 01, 2016 5:47 pm
Today's Sunday SLUK is a tech article expanding on a previous one I did with photos and video of an even cheaper test method.
I actually got this inner-tube method from someone on here but I can't remember who, so hands-up whoever it was, happy to give you credit in the article!
http://www.scooterlab.uk/engine-pressure-testing-leak-cheap-tech/
Sticky
Re: Leak-down testing on the cheap
Postby CHRIS in MARGATE » Sun May 01, 2016 5:52 pm
It was Coaster. He did it m'lord !
Simple but brilliant idea. That's how I do it now.
Postby Sticky » Sun May 01, 2016 6:00 pm
I'll edit to suit. I hope you are right Chris :)
Sticky
Postby Sticky » Sun May 01, 2016 6:05 pm
Fixed
Sticky
Postby Adam_Winstone » Sun May 01, 2016 6:25 pm
I like the hand operated bulb and gauge mechanism. Who supplies these? I've already got a set of bungs and plates to use but the foot pump and electric pump that I have don't allow the sort of control that the hand bulb does.
Good SLUK feature :)
Ta
Postby Scooterlam » Sun May 01, 2016 6:34 pm
It was a guy called Grandpa who had the original idea to use an inner tube on the inlet with the exhaust blanked off and a clamp affair on the other end of the tube.
It was My development to put the other end on the exhaust stub.
Scooterlam
Postby Sticky » Sun May 01, 2016 6:48 pm
Apologies ScooterLam, will fix again. Good tip
Sticky
Postby coaster » Sun May 01, 2016 10:01 pm
Scooterlam wrote:It was a guy called Grandpa who had the original idea to use an inner tube on the inlet with the exhaust blanked off and a clamp affair on the other end of the tube.
You beat me to it Derek, I couldn't in all honesty lay claim to this idea. I have used it to good effect though and suggested it to others 8-)
Postby CHRIS in MARGATE » Sun May 01, 2016 10:09 pm
Aha. It was your recommendation I remember and used.
Sorry for any embarrassment and potential loss of royalties !
And sorry too Grandpa.
Postby HxPaul » Mon May 02, 2016 10:33 am
Adam_Winstone wrote:I like the hand operated bulb and gauge mechanism. Who supplies these? I've already got a set of bungs and plates to use but the foot pump and electric pump that I have don't allow the sort of control that the hand bulb does.
Ta
I use the cycle inner tube method and a footpump,it kept on loosing pressure,I sprayed everywhere and couldn't find the leak.Eventually found it,it was the pump internal seals,I dis-connected the pump and the pressure remained at 7psi all night.
Postby coaster » Mon May 02, 2016 11:49 am
Sticky's article doesn't mention that the piston needs to be towards bdc otherwise you won't test the cylinder head gasket/spark plug seal.
The blood pressure testing kits are available on ebay Adam very not very much, I don't think I paid more that £10 for mine.
Postby Adam_Winstone » Mon May 02, 2016 12:08 pm
Good feedback, thanks guys.
Postby TVSi » Mon May 02, 2016 3:36 pm
Looks perfect, great way of testing the integrity of your motor.
Quick question, can I ask what size inner tube you used? I feel this will help people who use a stub type exhaust source one that not to small (or big) thanks
TVSi
Postby coaster » Mon May 02, 2016 7:08 pm
Eden wrote:....can be tricky on a piston port motor having it at bdc, although given a few seconds to equalise the air does get round the piston skirt :) or you can blank the inlet and pump from the exhaust side with the piston at bdc!
Yes I think you are right, the piston would be best with the transfers just open? I did wonder about air getting past the rings but then though on a rebuilt engine they might be abnormally gooped up with 2 stroke oil?? TBH, I didn't think too much about it last time I used the method, only heard it mentioned later :?
Mountain bike inner tube worked for me, £2.99 from Asda.
Postby CHRIS in MARGATE » Mon May 02, 2016 7:21 pm
No they've gone up Colin !
About £4 now.
Postby Scooterlam » Mon May 02, 2016 8:06 pm
as long as the exhaust is open it shouldn't matter as the tube is connected to both inlet and exhaust, another advantage of the tube over dearer plug based kits :D :D
Scooterlam
Postby grandpa » Thu May 05, 2016 8:01 am
Hi Sticky,
This was the original post
viewtopic.php?f=10&t=140&p=524&hilit=cheap+leak+test#p524
Update just watched the video on SLUK. Not sure why use a blood pressure pump instead of bicycle pump?
Do you have high blood pressure and no bike :lol:
Grandpa
PM sent
grandpa
Postby Sticky » Thu May 05, 2016 11:54 am
Sticky
Sticky wrote:A blood pressure pump is better because it only goes up to 6 PSI so the scale is clearer as it drops. If you use too much pressure too high you can turn the oilseals inside out.
A blood pressure pump is better because it only goes up to 6 PSI so the scale is clearer as it drops. If you use too much pressure you can turn the oilseals inside out.
Sticky
Postby Feersum Injun » Thu May 05, 2016 3:59 pm
I struggled with the inner tube method, I think I just had the wrong size! It would always leak at the carb manifold. Here's the kit I rustled up on ebay for about £15 and it works a treat. Sticky is right about using the blood pressure bulb and gauge. It measures up to 300mmHG which is about 6lb/in2. I used 32mm and 42mm plumbing blanks to fit over the manifold and exhaust stub with air fittings going through the one onto the carb manifold.
Feersum Injun
