Scoot Rs lambretta front disc
Postby neil64 » Sat Mar 05, 2016 1:42 pm
Hi,
Fitting of a lambretta front disc, we have noticed that that wheel rim doesn't sit onto the
Mounting points properly,we 've noticed that rather than the rim sitting flat onto the mounting points it doesn't actually fit properly, the mounting studs are located correctly ,any ideas .
neil64
Re: Scoot Rs lambretta front disc
Postby rossclark » Sat Mar 05, 2016 1:54 pm
What sort of disk is it?
What type of wheel?
Have you tried a different wheel?
AF Wheels tubeless are alleged to sit off the hub shoulder a bit. This has been raised as an issue by some who say that this means the wheel is attached only by the studs and the wheel holes. Others say this isn't a problem.
Postby Wack » Sat Mar 05, 2016 6:52 pm
If the rim won't sit flat, very often the hub needs filing down more on the lugs chamfer where the studs screw in.
