Dl125 motor rebuild
Dl125 motor rebuild
Postby Kristof Lammy pie » Tue Mar 01, 2016 1:46 pm
I've just managed to buy a complete dl125 motor. Having never stripped or rebuilt a motor the plan is to have a go at rebuilding a spare motor rather than work on an original motor from one of my scoots
I'm looking at some kits and im quite keen on a old skool cast iron kit and tune. I know Gori do a kit any views on others? what sort of Specs etc?
Any advice would be welcome ie
What I should avoid, what should I definitely do during the build, gearing. Cranks etc.
I know its a small block motor but I want to achieve a very fast motor with reliability.
Kris
Kristof Lammy pie
Re: Dl125 motor rebuild
Postby Kristof Lammy pie » Tue Mar 01, 2016 2:44 pm
Just realised the gt186 is cast iron ;-)
Kristof Lammy pie
Postby rexton270s » Sun Mar 06, 2016 1:07 pm
GORI have a offer on at the moment on there small casing kit,maybe worth a look!
rexton270s
Postby Kristof Lammy pie » Mon Mar 07, 2016 11:19 am
Cheers will have a look at the Gori stuff.
Kristof Lammy pie
Postby lammydave » Sun Apr 17, 2016 6:19 am
my friend has a casa 185.. does the job really well, I've just fitted a 200 muggy, early days, but seems good, also have the 186 version on a couple of scoots, highly reccomended
lammydave
Postby MickYork » Sun Apr 17, 2016 7:58 am
Quote: "I want to achieve a very fast motor with reliability"
Take your pick but you can't have both ;)
If it's only a cast kit it does narrow your options, The GT gets good reviews and advice is readily available.
Postby ToBoldlyGo » Sun Apr 17, 2016 12:26 pm
The gearing is an important thing to consider as well. Change the crown wheel and front sprocket and you've got a GP200 gearbox.
