gear slector spring
gear slector spring
Postby robert gilchrist » Tue Jul 01, 2014 10:35 am
Hi can anyway tell me if the Layshaft gear selector spring to buy are all the same length? i recently changed mine & it was longer in length, to the standard one i replaced with, could it be i was sold a kickstart spring instead?
robert gilchrist
Re: gear slector spring
Postby foremanbob » Tue Jul 01, 2014 4:06 pm
Both are OK to use.... The kickstart spring is a common upgrade to make the gear change more positive and firm. sometimes the standard spring can be a little loose and you can experience jumping out of gear...
foremanbob
Postby Wack » Tue Jul 01, 2014 5:55 pm
The gear spring is 0.8mm gauge , kickstart 0.9mm . The old gear spring may be shorter due to being compressed.
Users browsing this forum: Baidu [Spider], Google [Bot] and 80 guests
