Augusto Timing
Augusto Timing
Postby jonno » Fri Jan 01, 2016 11:52 pm
Whats the ideal tickover degree setting for an Augusto 600 fitted to a 225 mugello 26mm dellorto jl3 pipe?
jonno
Re: Augusto Timing
Postby coaster » Sat Jan 02, 2016 8:42 am
Something like 22 degrees but it is important to check that it retards fully to 16-17 before it hits 6k rpm
Re: Augusto Timing
Postby CHRIS in MARGATE » Sat Jan 02, 2016 10:07 am
Mine is around 23 at tick over and it retards to about 16/17 at 6000rpm. Nice to have a tacho because you can see how it works through the rev range. At 5000rpm, probably the speed I normally cruise at my timing is just under 19 and I am happy with that.
I have revved it whilst strobing way beyond that to 8750 and it holds at 16. Nice to know that it's not going to revert back !
