GT kit?
GT kit?
Postby Wack » Sun Dec 06, 2015 9:16 pm
I'm hoping, fingers crossed, to maybe do the 2017 Euro to Italy and would like to use my original condition 150 Special, but as standard it does 55ish tops so was considering an upgrade to maybe the GT 186 kit purely for the reason that if it siezed I may be able to do a roadside repair compared to nicasil and hopefully be able to cruise at 60+mph. I have an original TV 175 cylinder I could use with an TS 185 piston but like the reed valve for fuel efficiency and torque although I have an LTH reedblock spare. The idea was to use a 42mm Clubman exhaust and a 25mm Dellorto running thru the airbox so if anyone runs a similar spec GT kit or has done a TV conversion your comments would be appreciated.Thanks
Re: GT kit?
Postby Covboy » Sun Dec 06, 2015 10:19 pm
Hi Wack
You suggestion is exactly what I did . I'm really impressed with the kit - I've really enjoyed riding it this year with the GT186 kit - all straight form the box, no problems
viewtopic.php?f=19&t=2333
I'm gonna buy another + the gt crank for my series 2
Re: GT kit?
Postby Wack » Mon Dec 07, 2015 11:52 am
Thanks for the reply I've heard they're good for 65 ish?
Re: GT kit?
Postby Covboy » Mon Dec 07, 2015 12:35 pm
I have consistently achieved 70mph - it feels like it has more to give
Re: GT kit?
Postby burnside » Mon Dec 07, 2015 1:52 pm
Covboy wrote:Hi Wack
I've got a GT186 and the GT crank in my Series 2, along with a 30mm Delly and Franspeed Race it pulls like a train :D
burnside
Re: GT kit?
Postby Wack » Mon Dec 07, 2015 6:37 pm
Have you all gone 58/107 on the crank? What app are you using Covboy?
Re: GT kit?
Postby Covboy » Mon Dec 07, 2015 7:53 pm
Crank = standard Li 150
App = Pirelli Diablo Super Biker - free on App Store
Re: GT kit?
Postby dickie » Mon Dec 07, 2015 8:24 pm
Covboy, what gearing are you running?
Re: GT kit?
Postby Covboy » Mon Dec 07, 2015 8:54 pm
Hi Eden - that's dissapointing!!!! On that basis I guess mine does about 48mph max!!! :(
Re gearing - just standard which I think is 15:46
Re: GT kit?
Postby Wack » Mon Dec 07, 2015 9:49 pm
I had that app but could never get it to find the satellites so I deleted it.
Re: GT kit?
Postby Toddy » Mon Dec 07, 2015 11:06 pm
Eden wrote:
Covboy wrote:Hi Eden - that's dissapointing!!!! On that basis I guess mine does about 48mph max!!! :(
no it was blip. :lol: ill find the graph and upload the pic
it does read higher than my gamma but only a couple of mph.
Is it a Lambretta speedo app ;)
Re: GT kit?
Postby burnside » Tue Dec 08, 2015 1:57 pm
Wack wrote:Have you all gone 58/107 on the crank? What app are you using Covboy?
I've got the GT 60/110 crank and using Li150 box 17/46
burnside
Re: GT kit?
Postby coaster » Tue Dec 08, 2015 6:37 pm
That would be about 4.6:1? is that a 186 or 200?
Re: GT kit?
Postby burnside » Tue Dec 08, 2015 11:45 pm
Yes 4.6. I'm running the same gearing on both my 186 and 200 Colin. Only thing I will say with the 186 and Franspeed Race is that I find I have to change down to 3rd more often to keep it in the power band, whilst I don't have that with the 200 and BGM clubman. But as long as I don't let it drop below 60 it's not an issue :D
burnside
Re: GT kit?
Postby coaster » Wed Dec 09, 2015 9:45 am
burnside wrote:...Yes 4.6. I'm running the same gearing on both my 186 and 200 Colin. Only thing I will say with the 186 and Franspeed Race is that I find I have to change down to 3rd more often to keep it in the power band, whilst I don't have that with the 200 and BGM clubman. But as long as I don't let it drop below 60 it's not an issue :D
That's impressive, my Mk1 Muggy 186 couldn't cope with the same gearing and I had to drop to 15 on the front sprocket :(
Re: GT kit?
Postby Train driver » Thu Dec 17, 2015 4:53 am
I use strava for walking and cycling and one night I used it to check my Vespa speedo, max speed 77mph 8-)
The next morning I had PM's and emails from irate cyclists !!!! Strava had downloaded my results and I had smashed local PB's on a 10k route :lol: :lol: :lol: :lol:
All these quick boys wanted me off so they could have their table positions back.
edit. found them.
blip like I said lol
more normal
Train driver
Re: GT kit?
Postby Adam_Winstone » Sat Dec 19, 2015 12:45 pm
"I use strava for walking and cycling and one night I used it to check my Vespa speedo, max speed 77mph 8-)
All these quick boys wanted me off so they could have their table positions back."
^... that is *'ing great (lol)! Again, people more worried about what their PC is broadcasting to the world (same as idiots that care only about dyno results), rather than 'real world' results.
:lol:
Re: GT kit?
Postby jonw » Mon Dec 21, 2015 5:17 pm
Their Strava log was a recording of a "real world" effort and I can see why they would want you off.
jonw
Re: GT kit?
Postby Adam_Winstone » Mon Dec 21, 2015 5:23 pm
^... Indeed but Eden was faster!
