Case repair
Case repair
Postby Scooterlam » Tue Nov 24, 2015 12:46 am
I've got a 200 case that suffered when the piston skirt fell off and tried to escape helped by the crank.
Usual damage in front of the bump stop and a hair line crack opposite.
What's the best welding method which wont result in distortion.
Scooterlam
Re: Case repair
Postby coaster » Tue Nov 24, 2015 1:25 am
I think a 'slug' is inserted to absorb the heat and prevent distortion, CS Engineering in Norwich are good or what about the guy that did the Avanti Crankcase induction mods?
Re: Case repair
Postby Scooterlam » Tue Nov 24, 2015 7:50 pm
I've limited knowledge of welding,
Would electric welding tig or mig. Not sure of the difference, have less chance of distortion than gas.
Scooterlam
Re: Case repair
Postby Captain Pugwash » Tue Nov 24, 2015 8:05 pm
In my opinion Tig is going to give the best weld result, but it has a higher heat transfer to the work piece than MIG.
MIG could be used and can work very well on aluminium having less heat input, but expect a small amount of distortion which ever method is used because alloy expands when it's hot and contracts as it cools, the more welding that's done the more distortion you usually get.
Captain Pugwash
Re: Case repair
Postby bob » Wed Jan 06, 2016 11:44 pm
Personally I would favour TIG welding over MIG, the finished weld quality on repairs like this is generally higher with better fusion etc provided it is done correctly
bob
Re: Case repair
Postby Ralph95 » Fri Jan 08, 2016 6:01 pm
Tig is the way
where are you based I could weld it and do any machining I Am in somerset
Ralph95
