Another clubman question
Postby Scooter Paul » Mon Nov 02, 2015 9:45 pm
How much difference to performance will a clubman type silencer make to an otherwise standard 200 with a stage 4 Indian barrel. Carb is a stock 22mm Delorto? I appreciate jetting issues if I use a clubman but I have a NOS silencer and if the difference is not that great I'll save myself a few bob on my latest build.
Thanks, Paul.
Scooter Paul
Re: Another clubman question
Postby Dimitrios_231 » Mon Nov 02, 2015 9:58 pm
If noise is not a problem,
the Clubman will perform better,you'll get improved acceleration with higher maximum speed,
the noise will also make it feel sportier :)
the first time that I had changed from a standard box to 42mm AF I was amazed from the difference,
it might not look great difference on a dyno graph,but on the road the feeling was quite noticable,
it was on similar setup like yours,a MM 200cc with 22mm Dellorto.
Dimitrios_231
Postby Scooter Paul » Wed Nov 04, 2015 12:24 pm
Thanks for the reply but I'm still undecided!
Paul
Scooter Paul
