ron moss avanti 225
ron moss avanti 225
Postby rexton270s » Thu Jun 19, 2014 11:21 am
ron sent me a one off kit a few weeks ago,looks like qualty,am using a flatslide 30 delly a franspeed race varietronics af performence 58mm 107 conrod and a read speed 5 plate clutch! my question is there anyone with a simlar setup?? :?:
rexton270s
Re: ron moss avanti 225
Postby Adam_Winstone » Thu Jun 19, 2014 1:54 pm
Sounds similar to Ron's demonstrator (30mm VHSH and Fran Race) so his setting are worth getting hold of.
I run mine with 30 PHBH, Fran Supertourer and Agusto 6000 unit. My ignition range is something like 24 to 14 degrees, which might help as a starting point for your Varitronic (subject to varitronic ignition curve).
Postby jonoy » Thu Jun 19, 2014 5:30 pm
Adam_Winstone wrote:Sounds similar to Ron's demonstrator (30mm VHSH and Fran Race) so his setting are worth getting hold of.
now has 35m makuni
jonoy
Postby Adam_Winstone » Thu Jun 19, 2014 5:49 pm
No doubt that Ron would have records of his old settings/jetting though.
Postby MickYork » Thu Jun 19, 2014 8:47 pm
I'm running a 30mm PHBH, Franspeed Race and MTech.....i did have a Variotronic but changed it for a BGM stator and the the MTech. I've just changed from 4:6 gearing (using a Franspeed Tourer) to 4:8 for the race.
Postby rexton270s » Sun Jun 22, 2014 2:41 pm
MickYork wrote:I'm running a 30mm PHBH, Franspeed Race and MTech.....i did have a Variotronic but changed it for a BGM stator and the the MTech. I've just changed from 4:6 gearing (using a Franspeed Tourer) to 4:8 for the race.
am on sx200 gearing 4.82 final drive am hoping to give my mate rb a bloody nose!!
rexton270s
Postby MickYork » Mon Jun 23, 2014 7:39 pm
Keep on hoping.......
Just got back from Newark (80 mile) did 60+ (GPS) on the A1 all the way back without a sniffle, it accelerates from 60 quite easily but mid 70's seem to be it's limit (with my set-up).
I can't fault my Avanti but it's not a kit for a "Street Racer" (yet!!). An Avanti may give the RB a bloody nose but it would have to be an 100 mile "sprint" :o
Postby rexton270s » Tue Jun 24, 2014 6:18 pm
MickYork wrote:Keep on hoping.......
how did u find the running in mick?? pain or pleasure??
rexton270s
Postby MickYork » Tue Jun 24, 2014 6:54 pm
Frustrating !!! A pain to hold it at the recommended MPH but a pleasure to know there was lots more to come. I think i was one of the first to get one up and running so did the running in by the book....went out on a night after work for 20, 30, 40 mile at a time and managed to get a few 100 mile stints in on a weekend. The power was there but you couldn't use it !!!
I've helped put another 2 Avantis together and the running-in bit went out of the window with them. They both did a sensible 100 mile or so then started opening them up......no harm done (as off yet). The Avanti kit seems very forgiving and the reliability is a pleasant surprise (for a Lambretta).
Postby jonhunter » Sun Jul 13, 2014 12:55 am
Hi Mick
I have an Avanti with varitronic, what difference did it make taking the varitronic off?
Many thanks
Jon
jonhunter
Postby MickYork » Sun Jul 13, 2014 9:21 am
I tried running at a static 17 degree and it bogged down badly. It was so bad i was struggling getting a tick over. i went to Whitby with the set up and stalled going round a corner when i missed a gear, took an age to start.
Fitted the M-Tech at 24 degrees and it's cleared up the bottom end massively. No problems starting (hot or cold) although slightly boggy mid-range but i can live with that.
I think the Race exhaust doesn't like the low rev's and is the "problem". But it's a problem you can live with when you're on the motorways :) Not nice to ride around town but is there such a set up that gives town riding and motorway power ?
Postby Scooterlam » Sun Jul 13, 2014 10:23 pm
Yep,
and ive got it 8-)
Scooterlam
Postby bamrattle » Mon Jul 14, 2014 6:56 am
rexton270s wrote:ron sent me a one off kit a few weeks ago,looks like qualty,am using a flatslide 30 delly a franspeed race varietronics af performence 58mm 107 conrod and a read speed 5 plate clutch! my question is there anyone with a simlar setup?? :?:
Iam still waiting for mine
bamrattle
Postby mark1 » Tue Jul 15, 2014 1:19 am
I'm (hopefully) going to be getting an avanti kit in the next couple of weeks. Whats the best Exhaust to use with them?
I'm not sure what is the best set up to use. I want an all rounder that can tootle along on a ride out without much fuss and when required hit the motorway 2 up and a load of lugguage.
mark1
Postby rexton270s » Tue Jul 15, 2014 7:56 pm
hello mark1 if you ring ron he will put you on the right route! his a gent!! :D
rexton270s
Postby jonhunter » Sun Jul 27, 2014 1:47 pm
MickYork wrote:I tried running at a static 17 degree and it bogged down badly. It was so bad i was struggling getting a tick over. i went to Whitby with the set up and stalled going round a corner when i missed a gear, took an age to start.
Hi Mick
What carb and settings are you running?
jonhunter
Postby MickYork » Sun Jul 27, 2014 2:31 pm
Hi Mick
4:6 gearing with the Franspeed Tour and 4:8 with the Franspeed Race
30mm PHBH open mouth
124 main
54 pilot
70 choke
av266
x7 2nd clip down
40 slide
4 plate clutch with MB springs (20 + HP on the Dyno and no slippage)
AF mid-weight flywheel
M-Tech (24 retarding to 16)
BGM stator (full DC)
GP 200 indian g/box 46 crown 19 front
Squish 1.2mm
running 2% fully synthetic Exol
MEC 57mm Crank
about 9 miles to the litre.....was doing over 12 with the Ron Moss clubman
3rd year on the road and no top end problems.
Postby corrado » Fri Aug 08, 2014 3:19 pm
MickYork wrote:M-Tech (24 retarding to 16)
What setting did you use Mick?
corrado
Postby MickYork » Sat Aug 09, 2014 3:38 pm
seem to think it was setting number 6......will tell you if different.
Postby jonhunter » Mon Aug 11, 2014 12:06 am
[quote="MickYork"]I'm running a 30mm PHBH, Franspeed Race and MTech.....i did have a Variotronic but changed it for a BGM stator and the the MTech. I've just changed from 4:6 gearing (using a Franspeed Tourer) to 4:8 for
Is it running cleanly now? Ive got 30mm phbh, 120 main, 57 pilot, 40 slide x7 needle second clip down, franspeed race,
Af road 6 plate, bgm stater agusto 6000, seems go well
jonhunter
