Can I take a TS1 barrel out to 72mm?
Postby Simon ELC » Thu Aug 27, 2015 10:09 pm
I need a re-plate on a TS1 and was hoping to maximize CC.
Boring out to 72mm would leave the spigot 1.4mm thick.
Is this too thin and could it break in the motor?
Anyone had any experience?
Simon ELC
Re: Can I take a TS1 barrel out to 72mm?
Postby berniek » Fri Aug 28, 2015 3:39 pm
IMO Yes it is too thin and yes it will flex and break. I would not go beyond 71 mm on a standard spigot, and even then would shorten it.
berniek
Postby Simon ELC » Mon Aug 31, 2015 11:37 am
Thanks Bernie, I thought I was being a bit optimistic.
Simon ELC
Postby hullygully » Mon Aug 31, 2015 12:05 pm
I think AF's can steel liner it & use a RB/Rapido250 piston, with a couple of oversizes, I'm sure they did that for a mate of mine
Postby berniek » Mon Aug 31, 2015 8:35 pm
I spoke to Paul at PJME in Wolverhampton who have iron lined a few barrels for me about the possibility of running 72 mm on an iron lined with standard spigot diameter. I thought it might be strong enough to cope. He advised against it and thought that it would fail. Having had a spigot fail on me before I didn't want to risk it.
berniek
Postby Warkton Tornado No.1 » Mon Aug 31, 2015 10:58 pm
If you are looking for an increase in capacity, with a two stroke, an increase in the stroke is theoretically better as most of us already have engines oversquare. Two stroke MX engines are undersquare. It is also a practicable proposition these days for Lambrettas, & one I would advocate.
However, there is mention of the Rapido 250 & I just wanted to say that I believe the spigot on those barrels is larger, necessitating modification of the crankcase mouth.
Postby carlos fandango » Tue Sep 01, 2015 8:39 pm
Ive got a steel linered rb thats 72mm , std spigot (75mm).....done by pjme to 71 mm, did over 10k miles on it ....I had it rebored over the winter to 72 mm , done over 2k miles so far , no problems yet .....with the spigot .
Russ
carlos fandango
Users browsing this forum: Google [Bot] and 61 guests
