volt meter fitting
I'm going to fit a volt meter to my dc serveta lynx. My question is. is it best to wire it in to the output from the regulator or the input to the battery. cheers, Gary
https://ilambretta.co.uk/forum/
missing lynx wrote:I'm going to fit a volt meter to my dc serveta lynx. My question is. is it best to wire it in to the output from the regulator or the input to the battery. cheers, Gary
Scooterlam wrote:I could be wrong but isn't it essentially the same thing, as there is continuity between the two. Unless the input to the battery is the other side of a switch.
