volt meter fitting
volt meter fitting
Postby missing lynx » Wed Aug 19, 2015 8:07 pm
I'm going to fit a volt meter to my dc serveta lynx. My question is. is it best to wire it in to the output from the regulator or the input to the battery. cheers, Gary
Re: volt meter fitting
Postby Scooterlam » Wed Aug 19, 2015 9:15 pm
I could be wrong but isn't it essentially the same thing, as there is continuity between the two. Unless the input to the battery is the other side of a switch.
Scooterlam
Postby Digger » Thu Aug 20, 2015 7:42 am
missing lynx wrote:I'm going to fit a volt meter to my dc serveta lynx. My question is. is it best to wire it in to the output from the regulator or the input to the battery. cheers, Gary
Why?
Digger
Postby coaster » Thu Aug 20, 2015 11:29 am
Scooterlam wrote:I could be wrong but isn't it essentially the same thing, as there is continuity between the two. Unless the input to the battery is the other side of a switch.
Absolutely correct, it doesn't matter where you connect the volt meter, any switched live will do and earth. If you connect it to the regulator or battery it will be reading all the time.
Postby missing lynx » Thu Aug 20, 2015 2:52 pm
thanks for your replies now I'm probably going to answer my own question. option 1, if I connect it between the regulator and the ignition when the engines not running ignition off the batteries isolated so the volt meter will be off. option 2, if I connect it between ignition and the battery it will be on all the time so I'm best to use option 1?
Users browsing this forum: Google [Bot] and 34 guests
