headset vibration
headset vibration
Postby bazza3004 » Sat Jun 27, 2015 7:48 pm
Hi i am getting a fair amount of headset 'judder' just above tick over and also i get vibration through the headset at certain rpm(quite low) whilst riding. I have changed :- engine mounts. Front and rear springs crank from a 58/107 AF welded to a chiselspeed built 60/110 . Made sure the inlet manifold and carb arnt touching anything . I had a GT 186 kit on first and now a Imola kit and hqd the vibrations with both. The only thing i havent replaced is fork bearings but the steering is nice and loose with no play in the bearings that i can feel. The engine was stripped and rebuilt with all new bearings and seals etc. I dont no what else to change / do to cure this so have basically lived with it as its not unrideable by any means but wondered if anyone had any advice or ideas on this.
Thanks. Baz
bazza3004
Re: headset vibration
Postby Wack » Sun Jun 28, 2015 8:42 am
Have you checked the 3 bolts that hold the clamp to the headset and also for any play in the throttle tube and gearchange ?
Postby bazza3004 » Sun Jun 28, 2015 12:08 pm
Il check bolts but fairly sure its not the cause . Thanks.
bazza3004
Postby hullygully » Mon Jun 29, 2015 10:33 am
check your forks too :shock: :shock:
Postby Markpm » Mon Jun 29, 2015 5:26 pm
If your carb settings are miles out it can cause this
I had problems with my carb recently and the vibration when pulling away etc was horrendous
Sorted carb and vibration gone
Markpm
Postby bazza3004 » Mon Jun 29, 2015 6:13 pm
thanks for your replies. the carb is set quite rich at the min but as I say I had this same problem when it was obviously jetted lean (holed imola piston). it vibrates the headset if I hold it just slightly above tick over when on the stand and by this I mean you can see the headset juddering and also when riding I get some vibration through the headset in each gear when I reach a point in the rev range , not too high in the revs and this does clear with slightly more revs. ive changed mounts springs front and rear barrel kits , no play in forks although they are old bearings in there. I have resigned myself to having to live with this as its ok but just bugging me.
Lammys for you I suppose :D
bazza3004
Postby hullygully » Wed Jul 01, 2015 3:41 pm
does it judder when you brake also, if it does whip the forks out pronto & change the brgs, grease it up & re-tighten properly before you have to remove that lower brg housing as its a c**t to change!! :o :o :o
Postby HxPaul » Wed Jul 01, 2015 4:24 pm
I have a series 2,at tick over on the stand it shakes like a shiting dog,but open the throttle and the shaking goes.
Postby dave411 » Wed Jul 01, 2015 5:21 pm
HxPaul wrote:I have a series 2,at tick over on the stand it shakes like a shiting dog,but open the throttle and the shaking goes.
:lol: :lol: :lol:
dave411
Postby bazza3004 » Fri Jul 03, 2015 5:14 pm
Hi hullgully no its fine under braking mate just the symptons i mentioned in previous posts. Where as the headset will judder when on stand at around 1600(ish) rpm the vibration i get when riding at at certain rpm is no where near as bad just annoying. Prob more like its resinating than vibration.
bazza3004
