Internal diameter of fuel pipe
Postby Raveydavey » Fri May 22, 2015 6:04 am
for a fast flow tap, what is the best, most effective internal diameter of a fuel pipe? I think standard is 6mm but I have read people using 8mm. Is there a consensus on this? Google doesn't know. :shock:
Raveydavey
Re: Internal diameter of fuel pipe
Postby Toddy » Fri May 22, 2015 7:49 am
I use 8mm braided hose
Postby Raveydavey » Fri May 22, 2015 10:30 am
Thanks for the reply Toddy. Not seen braided fuel pipe before,sounds kink proof?
Raveydavey
Postby Toddy » Fri May 22, 2015 10:59 am
Raveydavey wrote:Thanks for the reply Toddy. Not seen braided fuel pipe before,sounds kink proof?
It's just rubber hosing with cloth type braiding quite flexible really :D
