60 mm crank
60 mm crank
Postby joe swoonara » Sat May 16, 2015 7:07 pm
just had to buy a new 60 x110mm crank and whereas my previous crank fitted o.k and spun freely my new crank the big-end is just fouling the casing , only just , how have people got round this , any innovative ways of trenching the casing at home , or who offers this service ??
joe swoonara
Re: 60 mm crank
Postby MickYork » Sat May 16, 2015 7:29 pm
Dremmel.....doesn't have to be pretty, just enough to stop it catching.
Re: 60 mm crank
Postby rossclark » Sat May 16, 2015 9:46 pm
Put some blue on the big end and relieve where it marks.
Bear in mind when you turn it to keep the small end fairly central as if in the barrel, that's where it will run.
Re: 60 mm crank
Postby Fat Trucker » Sun May 17, 2015 8:01 am
I used a flap wheel on a drill and that did the job, remember to mask drive side bearing up well before hand though.
Fat Trucker
Re: 60 mm crank
Postby hullygully » Mon May 18, 2015 11:43 am
would be best to blue or black felt tip the central area of your crankcase to see where the con rods touching
broady offers that service but £'s, but as previous helpfull comments state, see where it touches & carefully remove the material yourself
Re: 60 mm crank
Postby Dimitrios_231 » Mon May 18, 2015 1:05 pm
This is what I did for a 60mm crank,
up and down.
Dimitrios_231
Re: 60 mm crank
Postby joe swoonara » Mon May 18, 2015 11:22 pm
thanks ll for your help and comments looks like i`ll have a go with the dremmael and a flapwheel , thats a tidy job Dimitrios how did you do that??
joe swoonara
Re: 60 mm crank
Postby Dimitrios_231 » Tue May 19, 2015 12:34 am
I start using carbide burr then changing to a diamond burr,then smooth with cross buff or rubber abrasive burrs.
Dimitrios_231
Re: 60 mm crank
Postby Captain Pugwash » Tue May 19, 2015 12:08 pm
I have two different 60mm cranks to fit into two different engine builds, one needs no mods to the standard case but the other needs a small adjustment.
Captain Pugwash
Re: 60 mm crank
Postby bazza3004 » Tue May 19, 2015 11:54 pm
As stated above. Either a dremel or flap wheel in drill. Mine needed only a very small amount off rear of crank housing. I put 2 strips of masking tape in leaving a gap where big end runs and removed from this area.
bazza3004
Re: 60 mm crank
Postby Dimitrios_231 » Wed May 20, 2015 2:40 pm
Did the same for a 62mm crank with machined con-rod from AF
Dimitrios_231
