EGT sensor location
EGT sensor location
Postby mark1 » Wed Apr 22, 2015 10:03 am
I'm fitting an EGT but the instructions don't tell you where to locate the sensor, it just says "from the specified distance from the piston skirt" But doesn't actually say how far. I've done a search and can't find anything.
The sensor is a Gammatech and I'm fitting it to a franspeed with an Avanti top end.
Does anyone know how far it should be?
mark1
Re: EGT sensor location
Postby Lockman69 » Wed Apr 22, 2015 11:52 am
100mm from the skirt :D
Lockman69
Postby coaster » Wed Apr 22, 2015 1:11 pm
That's 100mm..ish, you'll need to be a bit flexible as 100mm puts it right on the first bend and with the Franspeed, close to the spring locating loops. A few mm either way won't matter as the temps will be unique to your engine anyway.
Postby hullygully » Wed Apr 22, 2015 3:48 pm
exactermondo ;)
Postby foremanbob » Thu Apr 23, 2015 12:30 pm
Oh and dont fit it on the exposed splash guard side of the pipe, as this can cause variations in the readings
foremanbob
Postby mark1 » Fri Apr 24, 2015 12:13 pm
Chhers chaps, fitted it last night. It works a treat.
mark1
Users browsing this forum: martyn dwane and 30 guests
