Brake hose.
Brake hose.
Postby Scooterlam » Mon Apr 20, 2015 10:01 pm
I need a new hose as mine is weeping from a crimp.
It's run from the master thru the side of the headset then follows the route of a standard brake cable
Can any tell me how long it should be or if any shop sells them lambretta length.
Really want to do it all in one go.
Thanks.
Scooterlam
Re: Brake hose.
Postby gizmo » Mon Apr 20, 2015 10:07 pm
I get mine from chiggy at lambretta upgrades, he will make it whatever length you want. Quality and good price
gizmo
Re: Brake hose.
Postby Toddy » Tue Apr 21, 2015 6:08 am
Derek, Chiggy does sell two set lengths round the fork like a normal front brake cable routing and a reverse pull length but he can also make up any length you want with any end fittings
http://www.lambrettaupgrades.co.uk/
Re: Brake hose.
Postby Scooterlam » Tue Apr 21, 2015 12:02 pm
Scooterlam
