Jim Rose wrote:In Switzerland last year the altitude played havoc with our bikes / jetting.
Jim Rose wrote:In Switzerland last year the altitude played havoc with our bikes / jetting. The altitudes this weekend are nowhere near as high but it will depend on the tune on his bike. Simply put the higher you go the less air . The mix will be richer and down jetting will stop it being boggy. Better that way than too lean when it's more likely to seize. The bike I'm using standard so I'm leaving it alone
a-teamlambretta wrote:tornado trev is doing the coast to coast this weekend and has some concerns over his jetting . as he is from darn sarf and there are no hills he thought i was bullshitting about re jetting for the high alltitudes that he will encounter , will he need to up or down jet ?? over the pass ??
hullygully wrote:well Si, @ least he attempted itgot furthest travelled up to Saltburn too
not bad for a shandy drinker........
missed you there
hullygully wrote:you know what they say about "all work & no play", you get a popeye left arm......![]()
Users browsing this forum: martyn dwane and 29 guests
