mb flat panel filters
Postby gaz_powell » Wed Apr 15, 2015 11:27 pm
anyone using them ? any feedback ?
https://lambrettaspares.com/spares/air- ... b0807.html
Gaz
Re: mb flat panel filters
Postby soullad » Thu Apr 16, 2015 11:32 am
Mate has one fitted, and it works great. Results backed up by a dyno run before and after with only a 0.5 HP loss in performance. Recommended !
soullad
Postby Storkfoot » Thu Apr 16, 2015 1:29 pm
Gaz I had one fitted on my S2 for Davos so it covered some miles. I agree that they aren't restrictive when clean. However, every afternoon I had to stop and clean the filter as it was saturated. This was on a reed valve GT186 too!
I replaced it with a breath sweet when I got back which is a bit more restrictive ( partly as the panel pushes the rubber in slightly) but I don't have to clean the foam all the time!
The carb is a PHBH 30 which I jetted. However, a dyno session confirmed that my jetting was correct. Just saying in case you think carb was at fault. May be better with a smaller carb??
Postby 68Sxandy » Thu Apr 16, 2015 3:41 pm
I had my Mugello 186 kitted SX dyno'd at Diablo and then fitted one later to try and stop some of the spitback, had no problems with it at all apart from having to wash it occasionally.
68Sxandy
Postby coaster » Thu Apr 16, 2015 4:36 pm
Storkfoot wrote:Gaz I had one fitted on my S2 for Davos so it covered some miles. I agree that they aren't restrictive when clean. However, every afternoon I had to stop and clean the filter as it was saturated. This was on a reed valve GT186 too!
I can confirm that, it was wringing wet and I believe the glue gave up in the end Paul?
Personally I can see how they seal properly with the amount of up and down movement of the suspension especially if loaded for a rally :?
Postby gaz_powell » Thu Apr 16, 2015 4:43 pm
thanks all
think i`ll give one a go
Or might make one with a less dense material - you can by sheets of air filter foam for not much
gaz
Postby Storkfoot » Thu Apr 16, 2015 5:27 pm
[quote="coaster
[/quote]
Yes, mate. Well remembered :) Being a Series 2 panel with a significant gap between the carb and the panel, I had to glue mine to the panel. Petrol and glue don't mix.
Postby mainstand » Fri Apr 17, 2015 3:53 am
No more nails worked for mine.
mainstand
