wassell circuit diagram
Postby drivera » Tue Mar 17, 2015 7:39 pm
On the old forum someone posted a schematic drawing of a Wassell regulator circuit using a capacitor instead of a Battery , anybody got it as I didn't get round to printing it off ?
drivera
Re: wassell circuit diagram
Postby Toddy » Tue Mar 17, 2015 9:06 pm
Not on this thread is it Andy from scooterotica .
http://scooterotica.org/forum/viewtopic ... conversion
Postby drivera » Tue Mar 17, 2015 9:54 pm
Hi Paul ta for that but it only shows battery circuits , somebody posted a wiring diagram showing a capacitor in the circuit of around 1600mf I think , which let you run without a battery , just wondered if anybody had it or if the person who posted it could put it on again :)
drivera
Postby coaster » Tue Mar 17, 2015 10:57 pm
drivera wrote:Hi Paul ta for that but it only shows battery circuits , somebody posted a wiring diagram showing a capacitor in the circuit of around 1600mf I think , which let you run without a battery , just wondered if anybody had it or if the person who posted it could put it on again :)
It's just a case of wiring the capacitor in place of the battery, the circuit diagram will be exactly the same. All a capacitor does is to store a small charge which it releases slowly in a similar way to a battery.
Postby drivera » Wed Mar 18, 2015 8:31 am
Cheers Coaster thought that might be the case , anybody know what size capacitor to use ?
drivera
Postby foremanbob » Wed Mar 18, 2015 8:58 am
That was me...
33000uF is good and cheap, but big enough to smooth it all out...
I have a spare in the garage.... PM me your address and I'll stick it in the post....
foremanbob
Postby drivera » Wed Mar 18, 2015 10:06 am
Cheers Bob you're a star , I'll buy you a beer at Scarboro :)
p.s. pm sent
drivera
Postby Patricks3179 » Fri May 22, 2015 10:17 am
From the photo I've got two Browns going in to the horn and two other leads taped up . Any ideas any one!!
Patricks3179
Postby Nelly » Fri May 22, 2015 12:03 pm
I can tell you the 2 browns are the 12V into the horn and back out to go up to the headset to feed the lights, or at least that's how it should be!
The white goes to the horn button- the horn sounds when the horn is connected to earth via the button.
As for the taped up stuff, time for a continuity test with the multimeter.
There's a wiring diagram that may help you here
Nelly
Users browsing this forum: No registered users and 17 guests
