GT Kit Carb Rubber Options
PostPosted: Sun Mar 15, 2015 2:38 pm
by Angry Bloke
Having a bit of a " laugh" trying to fit a 30 PHBH to a GT kit ( standard side ) with a 13ltr tank with cut out :?
It used to fit ok with an RT kit but the reed valve manifold appears to be shorter than the CDC type so the carb top hits the edge of the tank
Also the rubber is slightly nipped against frame tube
I have fitted a shorter 300mm shock which has dropped the barrel thus reducing the nip but I was wondering if there are any longer rubbers available
I've tried an MB rubber and a Mallossi rubber - the Mallossi is about 5mm longer and the diameter is slightly smaller which helps with both issues but is anyone aware of longer rubbers :?:
Re: GT Kit Carb Rubber Options
PostPosted: Sun Mar 15, 2015 3:13 pm
by dickie
I thought the 30mm manifolds were suitable for both sides now.
Have you got an old manifold? Or maybe it has to be used with a rubber from gran turismo?
PostPosted: Sun Mar 15, 2015 3:23 pm
by Angry Bloke
dickie wrote:I thought the 30mm manifolds were suitable for both sides now.
It's a new kit so presume it's the dual direction version.
I didn't realise Richard sold rubbers but I just found it as part of his carb kits - I will contact him later to see if they are any different from the norm
Cheers :D
PostPosted: Mon Mar 16, 2015 11:49 am
by Angry Bloke
I could always try the offset cone option I suppose :idea:
PostPosted: Mon Mar 16, 2015 2:56 pm
by Fat Trucker
Or buy some car radiator hose and cut to whatever length you require and you`ll have some left over for future projects.
ove
PostPosted: Mon Mar 16, 2015 8:23 pm
by Angry Bloke
Fat Trucker wrote:Or buy some car radiator hose and cut to whatever length you require and you`ll have some left over for future projects.
ove
:idea: thanks Ove - the Camlam rubbers are just lengths of hose I think
PostPosted: Mon Mar 16, 2015 8:41 pm
by coaster
What's the clearance like with you sat on it Peach?
PostPosted: Mon Mar 16, 2015 8:57 pm
by rexton270s
rad hose tis gud! had a imola and couldnt keep the phbh on......ford transit water hose did it!
